BOV supercharger
RE: BOV supercharger
It's a bypass valve which is similar to a BOV. What it does is close under boost causing all of the air entering the intake to be fed into the s/c for compression. When you let off (get out of boost), say to switch gears, it makes a PPSSSSSHHHHHH noise. The bypass prevents blower surge. There are bypass valves that let the air escape into the atmosphere (more used in racing applications) and there are bypass valves that recirculate the air back into the blower itself (used more on street applications with lower boost pressures).
With a turbo you will hit max boost (that you want) around 2500-3000 rpms depending on your set up which is why you need a BOV so you dont over boost. With a centrifugl supercharger you won't hit max boost till 6000 rpms so there is no need for a BOV. They work off of rpms so at 2500 rpms you might be around 4psi.With a screw type supercharger (like kenny bell) you hit max boost almost instantly but it will not go over.
ORIGINAL: oxfordgt
ORIGINAL: oxfordgt
you can setup the centrifugal blowers for a blowoff valve if you can move the mas so the bov is before it, otherwise itll just be venting metered air which is why they use bypass valves. the bypass valve keeps the already metered air and circulates it back through the blower.
Go to the mph forums and do some searching. Most centri's come with a bypass, not blow off valve. You can switch to a blow off but you have to switch your MAF from draw through to blow through, which I have read is harder to tune.
ORIGINAL: Triisomy21
