OMG!!! VALVES I need to know!!!!
Hey guys, I need valves for my 2001 pi heads, and I can't find specs or prices or even the valves anywhere. If you know anything about finding some OEM valves let me know. Thanks.
P.S. I'm tryin to do this on a budget so no 900$ valve sets. *cough*
RE: OMG!!! VALVES I need to know!!!!
If you are gonna pull everything apart your better off getting oversized valves anyhow. They need to be seated properly so oversized valves won't be much more at all. Your stock PI valves are 36mm exhaust and 44.5mm intake. You don't need a port and polish to go oversize on your valves. Actaully you'll have more lower end torque than the P&P with same oversized valves!
You coukd order them up at any performance shop like Texas Hot rods or ebay? Just amke sure you know exactly what you are getting on ebay. Stock valves come with a 3 angle valve cut in the head and valve. You want to retain atleast that if not get a 5 angle job, but depending on who is doing th head work you may want to stick to the 3 angle job! Stianless Ferrea valves are really good, but unneccesary for your application, so just get something simple and cheap! You may want to think about just getting new heads! May beeasier. I just soldbrand spankin new PI heads for $700 with everything...
