Finally decided
Finally decided
I'm going to order a TB+plenum, M/T DR's, Shifter, CAI,springsand pulleys.until next month.should I go ahead and get axles or not? I have been ordering from Jegs whats the best site you guys know of? Hmm with all that and whats in my sig think a 13.60 could happen with good driving..or maybe better?
RE: Finally decided
13.6 should not be a prob.. with relatively good traction you could hit that with your sig.. the 4.10s will help alot if you can hook up.. Now if you drop the E/T Streets down to like 12 PSI and launch the **** out of your car, I don't see a low 13 being out of question. O yeah, when you launch like that, expect new axles to be coming not tooo far into the future. Suspension work will help you after that.
RE: Finally decided
Axles wouldn't hurt but you will need some differential work to accept stronger axles (31 splines, stock are 28 spline). If you're running slicks and doing 4k rpm launches I would recommend them. I don't see why a 13.6x would be hard to reach with your mods. You should be close with just 4.10's if you can launch and drive good. If in the future you plan on adding a supercharger don't waste your money on pullies.
RE: Finally decided
ORIGINAL: 04mineralgreyGT
BeatnikFink
10-01-2015 08:00 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
