I finally bought my stang! But are my gears stock?
Old 02-25-2007, 07:29 PM
bigtom
bigtom's Avatar
Default I finally bought my stang! But are my gears stock?
Bought my car from a dealer so couldnt talk to previous owner.
some stuff has been modded e.g. air silencer mod
The suspension has been done and wide wheels and tires.
When i looked at the axle it looks like the differential cover might be aftermarket as it it a dull silver color.
Am I wrong?
I am interested in some 4.10s or maybe 4.30s as I will only drive the stang on weekends and have no interest in ever trying to go over 120mph!
I was wondering if someone might have already installed some gears? How could I tell?
I dont know any other stang owners soI couldnt compare against another stang.
Any thoughts or suggestions?
[IMG]local://upfiles/36744/CBFE9583412246328AC0DA94DDBCC7B5.jpg[/IMG]
bigtom is offline
Old 02-25-2007, 07:35 PM
Fuel
Fuel's Avatar
Default RE: I finally bought my stang! But are my gears stock?
jack it up and count the # of turns the driveshaft has to make compared to the wheel making one turn
Fuel is offline
Old 02-25-2007, 07:36 PM
Clutch_2000GT
Clutch_2000GT's Avatar
if you can "safely" jack up the rear end you can check by turning your back tire one full rotation and counting how many times the drive shaft turns...for example with stock gears (3.27) you should have roughly 3 point 27 drive shaft rotations for one full tire rotation
Clutch_2000GT is offline
Old 02-25-2007, 07:42 PM
lizzyfan
Underboss
lizzyfan's Avatar
Try this:
http://tchracing.com/tech/gearcalc.p...selectedgear=2
lizzyfan is offline
Old 02-25-2007, 07:50 PM
bigtom
bigtom's Avatar
Thanks guys I will give it a try.
What about that diff cover though? stock or not?
bigtom is offline
Old 02-25-2007, 08:01 PM
lizzyfan
Underboss
lizzyfan's Avatar
ORIGINAL: bigtom
Sounds aftermarket, gotta pic?
lizzyfan is offline
Old 02-25-2007, 09:05 PM
SINISTER
SINISTER's Avatar
Use the gear calculator, it is pretty accurate so long as you make the correct inputs. As for the diff. cover, that could have just been changed without the gear swap.
SINISTER is offline
Old 02-25-2007, 09:16 PM
Shawn02GT
Shawn02GT's Avatar
are those rims chrome or polished aluminum?
either way:
black + chrome = [sm=hail.gif]
Shawn02GT is offline
Old 02-26-2007, 12:19 PM
str8wick3d
str8wick3d's Avatar
I was in the same situation you were in. I got suspcious when I beat my friends z28. Also when I drove a previous GT test driving I got a feel for the car, jumped in this one. Way diffrent story. Took it to the shop recently and they verified aftermarket gears. 3.73s.
str8wick3d is offline
Old 02-26-2007, 12:27 PM
mvr
mvr's Avatar
ORIGINAL: Shawn02GT
i agree, my stock bullits are nice but if i upgrade im going to get something chrome
and if you get gears get at least 4.10's since its a weekend car
i have my personal reasons why i havent and probably will not get gears on my gt but if i did they would be 3.73's or 3.90's
mvr is offline
Quick Reply: I finally bought my stang! But are my gears stock?
