limited slip acting up
how tough is the limited slip in 99 gts. i changed out the pinion seal added gear oil and the additive. ok at first whining a lil now guys said thet it might go away when the additive works in . does the 373 gears i got have anything to do with it.
RE: limited slip acting up
whats up im a ford tech and from my experiance a whine is usually from incorect shimming of the carrier or the pinion, u have to check back lash and clearances, if ur having problems with the LSD it will usually chatter when ur making slow turns
treesloth
09-28-2015 07:03 AM
