NPI and PI?
RE: NPI and PI?
96-98 mustangs ar non pi, this means that they have restrictive heads, intake manifold, and mild cams. The 99+ mustangs ar pi (performance improved). A PI swap is replacing the npi heads intake and cams with pi parts. This gives about a 50whp gain.
RE: NPI and PI?
ORIGINAL: GTMustang6921
may be a dumb ? but i bet a bunch don't know....whats the diff between PI and NPI and what do they mean? There heads to right?
RE: NPI and PI?
ORIGINAL: RipTide7
RE: NPI and PI?
ORIGINAL: Hash06
not to be rude but how do you have over 200 posts and still not know the diffrence between NPI and PI
RE: NPI and PI?
I knew that NPI was in the sn95 body's and that PI were in the edge bodystyle....i just didnt know the difference.
ORIGINAL: Hash06
RE: NPI and PI?
ORIGINAL: Zoie_daGT
That is correct. A nonPI head can only have cams 0.500 while the PI heads can be up to 0.550. The PI intake has an aluminum crossover to prevent cracking. The nonPI intake is very prone to cracking. The heads are as said, really restrictive. If you go to PI heads, you will also raise your compression abotu 1 point. Those are the main differences between nonPI and PI parts.
ORIGINAL: RipTide7
RE: NPI and PI?
ORIGINAL: RipTide7
RE: NPI and PI?
ORIGINAL: 00TropicGreenStang
You get like 45 hp at the crank.
ORIGINAL: RipTide7
