Does Your DashBoard Rattle?? I found a quick fix.
well, in most mustangs the dashboard rattles. mostly it is the plastic trim panel that goes from the vents down to the switches. that was the case in my car. pretty much it would always rattle. so i took some 1/2 inch think soft black weather stripping. cut it really skinny, about a 1/8 of an inch. and stuck it to the back of the plastic trim panel, there is a very nice flat part that is perfect to fit the weather stripping. it goes all the way around the back of the panel. you will need about 2 - 3 feet of it, to go around. walla NO rattles, solid as rock. i used thick and soft weather stripping so it would conform to the shape really good, and feel solid.
you can pretty much do this to any plastic part that rattles or squeeks in the car.
stuff needed:
-sharp blade
-and 1/2 inch thick soft black weather stripping.
here are some pics after the install, you cant even see the weather stripping.
[IMG]local://upfiles/17316/98E9322AACD5496EA55665AFEB12CA15.jpg[/IMG]
[IMG]local://upfiles/17316/41CB9889B86845ADA0A06882C24BB668.jpg[/IMG]
stuff needed:
-sharp blade
RE: Does Your DashBoard Rattle?? I found a quick fix.
two more
[IMG]local://upfiles/17316/5EDED942F4C74608B85CFA7718E7A6AC.jpg[/IMG]
[IMG]local://upfiles/17316/A542B9E1A3E94226A1B79AF55DF9C350.jpg[/IMG]
behind it, there is a nice flat part behind the trim panel that is about an 1/8 of an inch think. so i cut the weather stripping to fit. and stuck it on.
sorry no pics, this was a very spur of the molment thing.
if you pop the panel off, you will know what i am talking about. really easy to do.
ORIGINAL: sprostang
Man i`m glad mine doesn`t rattle. That would just drive me insane. [:@]
^^^^and yes, thoes are the RPMs that i used to get it.
ORIGINAL: korn253
I have an obnoxious squeek that comes from inside my dash, i have yet to find what is causing it. It really drives me nuts.
