gap between front fenders and side skirts
Hi all,
I am relatively new to mustang. I recently purchaseda 2000 GT. I just now noticed there is about an inche gap between the front fenders and the side skirts. Is that how it supposed to be? I just checked out the recall section. Since I purchased it used. Can I still bring it to the dealer for them to fix the hand brake and the seat belt problems? Will I be charged?
I paid $11G for a 2000 GT with 39k miles, leather, 5sp, air intake, and full exhaust. Is that a good deal or did I over pay?
Thanks,
Thanks,
RE: gap between front fenders and side skirts
It does not matter if you bought the car used as far as recalls are concerned. If there is a full recall (not TSB) they will fix it no problem.
The gap you are talking about is normal. My '04 GThas it too.
A TSB is a Technical Service Bulletin. It is not an official Recall.
It is a service advisory for the Ford techs that indicate that there may be an issue with a certain part(s). Ususally it is to their discretion whether they will fix a car showing some signs referenced in a TSB. Confused? You should be.
Look up top under Mustang Classifieds there is the spot for TSB's.
If your car is replicating some items as mentioned in a TSB then take it to the dealer with the printout and maybe they will fix it for free or maybe they won't (like in my case).
If I understand it correct it has to do with how your caster and camber are set I know for those that have aftermarket you can get the wheel pretty close to the skirts....
maestro1024
09-21-2015 02:40 PM
