3650 tranny fluid change
just wondering if those of you with the 3650 noticed and difference switching to royal purple synchromax, my cars only got 27K on it and i had the dealership replace some syncros early on when it was under warranty (probably at about 10 or so K) so its not that i need to change it, also is there a specific place to pour the fluid when you take off the shifter? or do i just pour it in there. i think it takes 3.6 quarts, which is different from the t45s which i believe are 3.2, im not sure though
RE: 3650 tranny fluid change
ORIGINAL: NeedStangSpeed
I believe if it's like all manuals, there will be a fill plug from underneath. But the last ford I'll dealt with had the t-45
if you do it from underneath you will need a pump or a piece of tubing long enough to turn the bottle upside down and squeeze it in. The fill plug is in a horrible spot on the passenger side of the tranny.
ORIGINAL: tcuallstar
TREMEC engineers have recommended Texaco-Havoline Dexron III/Mercon Non-Synthetic ATF. The most recent Ford owner's manuals specify 3.17 quarts of a non-synthetic Mercon ATF. There has been a significant amount of confusion regarding the proper capacity and proper type of ATF for the TR-3650 which may have a correlation with a rather large number of complaints about notchy shifting, shift "nibbling", noisy synchros, and grinding gears.
after doing some reasearch i put in about 3.2quarts of mobil1 synthetic ATF
here are some more links to read up on
http://forums.stangnet.com/showthread.php?t=680192
http://www.bullittarchive.com/WebHel...0_Overview.htm
http://www.mach1registry.org/forums/...d.php?p=291723
