nitrous timing
nitrous timing
I am ready to install my NX wet kit on my car. I have 1 step colder plugs TR-6 gapped at .030 I didn't do 2 steps since the N20 will only be used on occasion. The manufacturer says it's okay to run a 75 shot with no timing retard? Is that right. Will I be okay if I do just a 75 shot with no retard. I know I can get a switch to toggle between different tunes, but I really don't wanna spend $500 between the tune and chip switch! Please help only if you have had nitrous. No bogus replies rookies!!! Thanks
RE: nitrous timing
ORIGINAL: yellowgtstang18
i run a 100 shot with -2 timing set on my diablo tuner
RE: nitrous timing
For a 75 shot the max you will need to retard your timing is 2 degrees. With that little of retard you are only losing like 2 whp so its not that big of a deal if its retarded all of the time. If you are only going to use the nitrous once in awhile their is no reason to spend 300 for a switch chip and another 150 to tune it. But if you really want one look at americanmuscle.com.They have them and some accesories for it.
RE: nitrous timing
Id go to your local tuner and see what he has. I know im getting the SCT chip taht has the switch for my kit from my local tuner in a couple weeks.
Im running 100 shot with no timing retards and autolite coppers right now. No problems but I do plan on switching to NGK's and a timing retard for my 2 stage when i go 200 shot.
RE: nitrous timing
ORIGINAL: gsxrstang69
RE: nitrous timing
Yes i use at least 92/93 octane.Gas stations are retarded around here. My car requires it actually or it pings like a ****. No problems yet and ive gone through a bottle and a half with my setup.
