vortech mustangs please enter
03-01-2007, 10:23 PM
RE: vortech mustangs please enter
Quote:
ORIGINAL: Fuel
the 2000 had bbk shorties and catted pipe with flows, 35 lb injectors, and was at 17 degrees timing
but the dyno sheet said that it only saw 8psi of boost and the a/f was at about 10.8:1 after 4300rpm
That a/f ratiowas super rich alot of power is ate up right there. I'm running rightbetween 11.8:1-12.0:1 with 19* of timing all the way thru the rpm's at WOT safely with no signs of detonation. 12.0:1 a/f is about as high as I would go tho.
03-01-2007, 10:26 PM
Quote:
ORIGINAL: Fuel
yes it was a mustang dyno
and btw i am not going to change to pi heads, yet anyhow
A mustang dyno will read a little lower than a dynojet because they are load bearing dynos that create a simulated road load effect on the car.
03-01-2007, 10:31 PM
any more ideas for my car
03-01-2007, 10:37 PM
Maybe some suspension work(UCA's and LCA's), do it yourself intercooler, 75mm t/b and plenum, LT headers... The list goes on.
03-01-2007, 10:45 PM
where is the best place to pick up one of these kits
03-01-2007, 10:58 PM
Quote:
ORIGINAL: Fuel
s/c kit? I'd say Modular Powerhouse, jmschip.com, superchargers online, etc.
03-01-2007, 11:02 PM
i had a 97 gt with a S trim.. 8psi, npi, c&l intake 75mm throttle body, 3.73's and it had 320rwhp
03-01-2007, 11:09 PM
what is the difference between v1 and v2 and how much boost will the v2 s trim push
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
AMWill
AmericanMuscle.com
26
09-08-2015 01:32 PM
Soldier GT
08-12-2015 03:46 PM
daytooday
08-11-2015 09:22 AM
