Ideal air fuel ratio!
RE: Ideal air fuel ratio!
doesn't matter what motor you have I'm most + it's 13.2 alot of aftermarket chips run you 11.5-12.5 for lean power, but can be bad. You need an 80mm maf 21-24lb injectors, stock fuel supply will do the trick most of all a custom tune not a handheld junk box. Your car will never run full potential with one of those things. You need Live diagnostic tech support computer programs that they will not provide for you.
ORIGINAL: 97targa
Somewhere around 13:1 is the ideal range.
09-03-2015 07:14 PM
