NEW 2002 GT...Plans..what do you guys think?
Just got my new 2002 Mustng GT off ebay, see HERE
if you would like. Here are plans:
Phase 1
-Magna Pack Catback Exhaust
-Cold Air Intake
-3:73 Gears
-Underdrive Pullies
-Short Throw Shifter
Phase 2
-Lowering Springs, Shocks, Struts, Rear Sway Bar and Strut Tower Brace
-AcuFab ThrottleBody 75mm
Phase 3
-Ported & Polished Upper/Lower Intakes & Heads
-Custom Ground Camshaft
-Pushrods & Springs
-190/255 lph Fuel Pump
-Bigger Injectors
-Adjustable Fuel Pressure Regulator
-Custom Chip
Should all be pretty much in order. Any comments or suggestions are welcome.
Phase 1
-Cold Air Intake
-3:73 Gears
-Underdrive Pullies
Phase 2
Phase 3
-Pushrods & Springs
-Bigger Injectors
-Custom Chip
RE: NEW 2002 GT...Plans..what do you guys think?
I would look into it a little more. I looked at it for 5 seconds and read this...
Miles: 15,177
Transmission: 5 SP Manual
Engine: 4.6L V8 EFI 32V SOHC...
How do you get a SOHC 32V? LOL The GT is a SOHC 16V.
Miles: 15,177
i
i saw that to daniel seems kinda odd to me all that stuff in phase 3 bro is only for the 5.0s phase 1 is good get and o/r xpipe to
Well this is what I wanted to hear. I will stick with phaes 1 and 2...What is recomended for the 3rd phase of my vehicle? When I was researching I must have gotten something crossed. as for the SOHC 32, Its probably just an error the dealer made. I know he's legit because I have talked to several of his past buyers and they all praised him up and down.
Well I did a little reseacrh and the GT must not ONLY be SOHC 16v because i found a few others GTs with the 32v..heres a few links..what do u guys make of this?
Car 1
Car 2
That is just a few of the SOHC 32v i found, but if you search there many more....
So what does this mean? Whats the differance between the 16v and the 32v??
Car 1
Car 2
Guest
Posts: n/a
ORIGINAL: Hells GT
Car 1
Car 2
Car 1
Car 2
32 valves means 4 valves per cylinder, 16 means two per cylinder. A SOHC motor won't handle 32 valves.
