i think i broke my car (update)
RE: i think i broke my car
ORIGINAL: _UnLiMiTeD_
check you tranny level, sometimes if the fluid is just low enough, the tranny will make some funny noises, never know.
And Adam, apology accepted. But i dont drive my car **** poor. I am only 19, so you can imagine i do get on it from time to time. But i dont just tear **** up.
ORIGINAL: 02bluegtstang
your a ****in moron...leave this site you low-life piece of ****
ORIGINAL: Adam03GT
Yes it is possible but the chances are...... And yes there is a difference between driving your car and driving it **** poor stupid. Actually ant i apologize to you. I think im just a little steamed at the retarded drunk guys post about breaking his car... That guy is the real genuis.[:@]
that was a little harsh.
This forum really sucks. You guys have a hard time helping dudes with a prob. Im 6'4 245lbs if you have a prob come see me dip****. The guy has a prob with his car and you run your fukin mouth like the piece of crap you are. Sounds like your throw out or fluid level man. If you want a good site were you wont have to put up with these fukin loosers that got nuthin better to do then run there big mouths come to sn95forums. They will give you good info withouth the bulll****. You guys really suck im banning this site from my puter. My address is in my profile come see me sometimes ********.
oooookaaaaayyyyyy.......so...ant,i used to repair trannies at aamco and all i can think of is sometimes there is a half moon piece of sheet metal that covers the lower half of the torque converter on some bell housings...is prone to warpage from heat and stress especially if your trans and motor mounts are really worn or broken,any of these can make that piece "touch" the torque converter under a load and make a high pitched click sound,like you said only when on the gas.....try doing this....put in "D" and lightly power brake it only to get the motor to bind a little and see if it makes that noise only when you put it under a load...try it also in "R"...if when you bind up slightly,remember your not try to do a burnout just put it under a load with the brake applied....if you hear or feel a clunk or thud when you let off that means you got a broken mount somewhere....hope this helps.
