how much boost?
RE: how much boost?
12 would even be fine on a stock bottom end, so long as you're not pushing 450+ to the wheels. the psi isn't what kills our engine, it's the power that it gives you.
yes, now i have a built block, but i was hitting about 11psi before i did all this and now i have a 3.10" on and i'm hitting 13psi.
RE: how much boost?
once i hit 16lbs on a stock bottom end and it was fine.... normally i would hit 10-11 psi.... it runs fine with it.. i have a 3.33 inch pulley....... you probably have like a 3.6 or 3.8 inch pulley...
RE: how much boost?
ORIGINAL: nanaki
RE: how much boost?
would the 2.6 slip bad with the 8rib setup? cause im lookin for 18-22lbs too and the thought the pully was 2.6...im also gettin the richerd racing a/c delete pully witch you can tightin the belt even more...so i hope it doesnt slip
RE: how much boost?
ORIGINAL: 1BadSonicBlue02GT
O and i cant find any boost pulleys on ebay. where can i get them for a decent price???
also.... why do you stop at 5500 rpms? sounds like you have a 8psi pulley... it will make 8 psi around 5800-6000 rpms...
