maximum cubic inch
RE: maximum cubic inch
mod max used to make a stroker kit, believe it was a 4.5" stroke, combined with a dry/wet sleeve kit (max out at 3.7") it becomes like a 385 or something huge...but like said above, its fairly expensive
this is all i can find right now...
http://www.modmaxracing.com/stroker.htm
the site is www.modmaxracing.com
it says it can be stroked to a 350 which is the 5.7 but im not sure if you can get more.. thats still a decent size motor.. im sure with some boring you may get a 5.8-6.0 out of it.
Yeah I was thinkin more like 5.9L, but wasn't sure if it was slightly under 6 or slightly over. Either way it's a huge bore and will cost you a bundle but will be a bad set-up! I bet you could get 425rwhp out ofit N/A
ORIGINAL: 97targa
ORIGINAL: ZW99GT
Oh no problem. Even VT's "little" 324ci will go WAYYYY above that
ORIGINAL: 97targa
Yeah the motor in my dad's Shelby Cobra is a 351W bored out to 392cid. He's making at least 420rwhp N/A. But then again, the car weighs under 2000lbs and the driveshaft is only 1.5 ft long!
I'm not sure what the liters are on a 392cid? Anybody know? I know the 351w is a 5.8L.
ORIGINAL: CobraStangGT16
