Our Miles Stored??
Our Miles Stored??
Ok getting a gauge cluster this week. Our my cars miles stored on my cars computer or in the gauge cluster. And if there on my cars computer when i plug my cluster in will my miles just appear as nothing has happened.
RE: Our Miles Stored??
ORIGINAL: davidsv8mustang
ORIGINAL: Davojan59
haha that would be pretty badass if it went to zero huh hahaha id be buying one every oil change.
ORIGINAL: SVTBill
I don't usually call it out but it's "are", not "our"...only said something because it made the sentence hard to read...sorry.
ORIGINAL: 2000GT4.6
The new cluster will read the correct milage.
The mileage is stored in the CLUSTER! It is NOT stored in the computer! there has been MANY posts about this! Not only will the mileage be different, but your car will NOT start, and you may have trouble depending on what year the cluster is for and what year your car is! Check the link below for more info!
https://mustangforums.com/m_1734619/mpage_1/key_/tm.htm
ORIGINAL: SmallFeesh
You shouldnt post unless you are SURE you know what it is you are talkin about! Now this guy has WRONG info!
ORIGINAL: 2000GT4.6
It is a direct swap. Pull it out, swap them, plug it in, and bolt it back in.
There will be no issues with the car not starting or not reading the correct milage.
Like you said, don't post information unless you have the right answer. Code3 runs the autometer cluster, as does my buddy with a 02 GT, neither had any problems.
If you swap a cluster in from another car, espcially like the guy in the post you linked did that swapped a cobra assembly into a GT, you may run into problems. However, an aftermarket cluster specifically for your year of car will have zero problems.
Im not sure of the guages you are talking about... but I do know that if you replace the green switch board behind the cluster, it is actually attached to the cluster, this is where the mileage is stored as well as the PATS info (anti-theft device), it dosent say in his post what type of guages he is installing, I have no expeience with Auto Meter or the like guages, so I am unsure how they install...
