HELP WITH GEARS
03-05-2007, 03:28 AM
RE: HELP WITH GEARS
how much power should i expect
03-05-2007, 03:29 AM
RE: HELP WITH GEARS
is there anyway to fix the rpm's
RE: HELP WITH GEARS
The 4Vs seem to go with 4.30s usually. Since they rev higher 4.10s in a GT=4.30s in a 4V
03-05-2007, 03:31 AM
RE: HELP WITH GEARS
Quote:
ORIGINAL: 03machyellow
None. Its a torque multiplier. No real "power" will be gained, but you WILL feel the difference.
03-05-2007, 03:41 AM
RE: HELP WITH GEARS
so ford racing 4.10's?
03-05-2007, 03:42 AM
RE: HELP WITH GEARS
Unless you want to go extreme-ish and do 4.30, then yes.
03-05-2007, 03:44 AM
RE: HELP WITH GEARS
how big of dif
03-05-2007, 03:56 AM
RE: HELP WITH GEARS
Umm, Its hard to explain. I'll have to let someone else take a crack at this one. I have no experience with 4.30, nor with 4v's.
03-05-2007, 04:52 AM
RE: HELP WITH GEARS
Quote:
ORIGINAL: ZW99GT
about 10 - 15 miles a day to work whats bad with high way driving on them
Mine runs ~2750 at 75. Not too bad. 10-15 miles isnt bad at all. Go Ford racing 4.10's.
O damn. You dont consider cruising at 2750rpms a bad thing? That seems kinda high. I feel bad for cruising at 2200...
03-05-2007, 04:54 AM
RE: HELP WITH GEARS
Quote:
ORIGINAL: Adam03GT
Quote:
ORIGINAL: ZW99GT
Nahh. As long as its under 3k I'm cool
