Check engine light back on because exhaust leak
Old 03-06-2007, 09:00 PM
02bluegtstang
I ♥ Acer
02bluegtstang's Avatar
Default Check engine light back on because exhaust leak
So yea...I had an exhaust leak and that made the check engine light turn on again even tho I have the MIL Eliminators for my Prochamber...
so how do i get it to turn back off....should I just unplug my battery for like 10minutes so the computer resets?
Thanks
02bluegtstang is offline
Old 03-06-2007, 09:09 PM
02 Ninja
02 Ninja's Avatar
Default RE: Check engine light back on because exhaust leak
Could be one of you MIL's is getting a slow read. Same thing happened to me when I installed my LT's w/ MIL's. I took mine back and swapped them out. Problem solved
02 Ninja is offline
Old 03-06-2007, 09:10 PM
jsorell
jsorell's Avatar
do you know what code your getting? P0420 and p0430 would be caused by cats or mil eliminators not on. yes you can disconnect battery for 10 min and light will clear.. don't know of any codes caused by an exhaust leak... except maybe lean..
jsorell is offline
Old 03-06-2007, 09:11 PM
02bluegtstang
I ♥ Acer
i got two different codes for oxygen sensors....
i have gotten the leak fixed so everything should be back to normal now...
Old 03-06-2007, 09:14 PM
jsorell
jsorell's Avatar
what r the codes... im a ford tech i can look them up right now if you want!
jsorell is offline
Old 03-06-2007, 09:19 PM
sprostang
I ♥ Acer
sprostang's Avatar
Get a tuner and turn them off for good and then youwon`t have to worry about the CEL.
sprostang is offline
Old 03-06-2007, 09:27 PM
Othic
Othic's Avatar
damn that must be some leak. do you live up north where the roads are salted? this happened to mewhile i went to school intennessee. i just cleaned mine out and so far it hasnt come back. but its only been 2 days.
Othic is offline
Old 03-06-2007, 09:36 PM
genes01stang
genes01stang's Avatar
10-1 says the mils aren't working.......
genes01stang is offline
Old 03-06-2007, 10:04 PM
02bluegtstang
I ♥ Acer
the mils were working fine (ive barely had my OR Prochamber and mils for like a month)...
then the pipe got loose from the headers and i had an exhaust leak...
the check engine light came on...
i had the bolts put back on, but the check engine light is still on...i will try to disconnect battery for10 mins and see if that works....
Old 03-06-2007, 10:21 PM
jsorell
jsorell's Avatar
if the light comes back on... then you still have an issue. Might be something altogether different then exhaust. If you can tell me the code i could probably walk you thru it.
jsorell is offline
Quick Reply: Check engine light back on because exhaust leak
