2 questions about rims+nitrous
Ok first question is...I'm looking for rims to mount my 275/60/15 DRs. The BFGoodrich website says I can use an 8" rim. Since they are much cheaper I was looking at the following...but is that the right bolt pattern and the right backspacing...I don't know a damn thing about backspacing or what the hell it does. These wheels are for track only use
http://store.summitracing.com/partdetail.asp?autofilter=1∂=CRR%2D3975812P& N=700+4294923107+4294923105+4294793325+4294795098+ 115&autoview=sku
Alright the second question is...what fuel pressure safety switch do I buy for my NX wet kit? I've seen a few but I have no idea what to pick.
RE: 2 questions about rims+nitrous
yes on the wheels and you can get any brand Fuel safety switch as long as it's for EFI, which has greater fuel pressure. 25psi-50psi. I know the NX one is $50 compared to NOS one at $35, but they are esentially the same except the NX has 10psi more of a range on the upper end 60psi(you don't need this much anyway) you should set it at 50psi
http://store.summitracing.com/partde...p;autoview=sku
Will that work? I don't really get the whole pressure thing so I'm asking
Bump just need this last question answered
Damn also they say I need to buy 1 step colder spark plugs? Which ones..specifics please not just a brand name
If the fuel pressure drops too low the switch shuts off the nitrous soleniod to keep you from leaning out and blowing the motor. The fpss should be set around 25-30 lbs, unless you have a svt pump then you can raise it ,but you really dont need to. Setting it higher will cause the solenoids to chatter when the fuel solenoid opens and the pressure on the fuel rail drops.
[align=left] [/align]
ORIGINAL: M1ke
you dont have to have new spark plugs unless you plan on spraying a lot without a tune
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
