nitrous questions
nitrous questions
I got my mustang running in top shape, tune up all that good stuff. Im looking into getting nitrous. Can someone tell me what a safe shot the 4.6 can handle? Dry shot with a WOT switch sounds good right? thanks
RE: nitrous questions
idk about a 100 dry shot. sounds like too much without changing fuel pressureor something.
Go with a wet shot and get some NGK tr6's. Window Switch and WOT switch are nice but they are not a must.
You will most definitely want a bottle warmer.
i got some questions im new to nitrous i have a nx 100 wet shot on my 4.6 but when i open the bottle the pressure goes to about 700psi and wont go up afterwords.
and when im done using the nitrous after a few hours the pressure guage is almost all the way down could i have a leak? or is all this normal?
ORIGINAL: SofaKingFast
100 shot is fine. I picked up 93 hp at the tires w/ my 100 shot. Make sure you get a tune and one step colder plugs. I got the NGKs and was fine. I also did a wet shot but both have their pluses and minuses. 100 shot is the safe limit. You can go higher but after that, you are playing w/ fire, esp. w/ a dry shot. You will have to upgrade your injectors then too. Dont forget a fuel pump too.
well i have a bottle warmer i was just askin if that was normal. also is it harder to build pressure when u get less in the bottle? u got aim if so can u im me im greddyn0s thats a zero
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
