Cobra Question, looking to buy.
I have found a 1999 cobra, with 52k on the clock, hes asking 12 grand. All recalls were performed and serviced by ford and he has the documentation. There are some slight probelms with the vehicle what do you guys think about these problems and a few of the mods.
Do you tech guys think the timming chain would be a major probem? Is this actually common, or is this bs? What about the ABS light?
The timing chains make intermittent noise when cold, that goes away once the oil warms up. This is common with the modmotors. Does not affect drivability. The ABS light is on and it needs new rear tires soon. That is it. Has $2000 in mods, which are (just in case you forgot)-
3:73 Gears and complete rear end by Drive Line Specialties
B&M Shifter
BBK Intake
BBK 62 MM Throttle Body
Drilled rotors and performance pads
Nice hand made Cobra shift ****
Magnaflow catless x-pipe
Magnaflow Mufflers
This is his message.
B&M Shifter
BBK Intake
Magnaflow Mufflers
11-10-2015 11:39 AM
