WHEN IS IT TO MUCH AIR........
#21
RE: WHEN IS IT TO MUCH AIR........
Blackbetty,
I have already replaced the TPS sensor so i know that wasn't the issue. I did however, cover the wheel well area and left the ram air which was the easiest task i can try at the moment. The result........was no joy, just like a couple of youhave already determined.[&o]
By the way would you know the spark plug gap for a 99GT mustang, manual? The sticker on the under hood of my car that has that info,has corrioded off long ago.
#23
ORIGINAL: na svt
It is possible to have too much air.Ram air setups have been know to cause idle problems when the car is coasting to a stop with the clutch depressed and also at steady state operation. If the MAF is getting excess air volume it will result installingwhen coasting to a stop and also surging when cruising down the hwy.
