70mm BBK TB
70mm BBK TB
I just got a 70mm Throttle Body. Should i have gotten the 75mm TB? Am i really going to notice a diff. if did get the 75mm? I also got a trick flow plenum. Is that a good choice also? Please let me know.
RE: 70mm BBK TB
Prepare for 10 posts on, 70mm for N/Aand 75mm for FI, or if you are planning on getting FI in the future (Forced Induction, Supercharger/Turbo).
Followed by a few, You will not notice a difference-what a waste of money, or by others, I noticed a slight difference. But you shouldn't notice a difference between 70mm and 75mm, for a N/A car.For a FI car, you should notice a difference, and only go with 75mm.
I got the 75mm myself, but havn't put it on yet (accurfab tb and plenum), so I can't talk from experience, just the ton of postings I read before getting it myself. Will know in a few weeks if I can notice a difference, but it looks DAMN GOOD![sm=smiley20.gif]
RE: 70mm BBK TB
from what i have read, most tests show that you gain a few more hp with the 75mm throttle body over the 70mm.....even if you arent supercharged. the 75mm is usually the same exact price as the 70mm, so i dont see why not get the bigger and better one. it certainly wouldnt hurt. also think about it this way...the bigger the throttle body the more air you can pull in (assuming you have a good cai also), the more air you pull in, the more power you make.
RE: 70mm BBK TB
It depends to a great deal on the plenum you hook it up to--here's a link to Accufab's flow numbers for a variety of TB diameters and plenums (about 1/2 way down). Not exactly an unbiased soure, but it's the best comparison I've found.[/align][/align]Some plenums flow better with a 75, some with a 70. Curiously, with Accufab's plenum it doesn't matter...[/align][/align][/align]
RE: 70mm BBK TB
ORIGINAL: chachi
anyway, good luck. anything beats the shiznit out of stock!!!
RE: 70mm BBK TB
ORIGINAL: ctstanger
RE: 70mm BBK TB
ORIGINAL: chachi
What does the 5", 20" and ect...mean?
