Front Brake Help
Old 03-10-2007, 03:06 PM
Clutch_2000GT
Clutch_2000GT's Avatar
Default Front Brake Help
over the past few weeks my front brakes have been acting up more and more. I now have to put a lot more effort into getting stopped. I looked at the pads and they are fine. The brake pedal even feels looser, but when I depress the brake pedal hard it makes a sort of clunk sound and I start to hear a slight grinding/ vibrating. Also, my power steering went out a few months ago, could this have anything to do with it? I am planning on jacking it up and taking a look at it today and hoping to figure out whats going on. Any help would be extremely appreciated, thank you.
Clutch_2000GT is offline
Old 03-10-2007, 04:13 PM
Clutch_2000GT
Default RE: Front Brake Help
anyone???
Old 03-10-2007, 04:52 PM
Andrew00GT
Andrew00GT's Avatar
When i first bought my car my front passenger side calliper was siezed on the rotor, all needed new break pads and 3 or the 4 callipers had to be replaced. I found a lot of the clips on the callipe werent there.. I wuld put it on a lift and look at the calliper for, missing clips, erosion from the salt. and the rotors for smoothness. Wut i found the hard way was rotors will warp easily. I was plannign on having mine cut down n smooth again but they were already cut once so i hada get all 4 new rotors. After that i havnt a the slitest pull when i aply my brakes or any noise or looseness of the pedal. It gets pricey btu if i were you ide get new rotors and brake pads all around... if that doesnt fix it go to the calipers.
hope this helped, good luck
Andrew00GT is offline
10-07-2015 07:02 PM
PB Pod
Forum Issues and Feedback
09-17-2015 08:32 PM
09-16-2015 07:53 PM
09-08-2015 11:50 AM
Quick Reply: Front Brake Help
