About to purchase U/L Control Arms...
RE: About to purchase U/L Control Arms...
ORIGINAL: Davojan59
well ive actually heard of many road racing cars having UPR stuff on them...but either way even if it is so...thats what i bought them for!
Ah I remember reading about not needing upper control arms a while back, but I forgot the reasoning behind it..thanks for the info.
Now I am only going to buy a set of LCAs, but like I mentioned, I wanted something fairly cheap because I don't intend on making too much power or drag racing too often. Plans for about 350 wheel horsepower at most with drag radials--some street racing, not going to lie, and limited track runs since closest track is about 2 hours away!
Hrmms, I wouldnt know too much about the lower ones as I have been doing research on the ones for what my goals are 500+whp/wtq, I would guess check in with stangsuspension and see what they would recommend.
Oh and I just saw the picture, that is the same setup I will be going with mm coil overs/ta/phb/lca, how much did the shop charge you to reroute your exhaust pipes?
Maximum motorsports or Steeda for reliable parts.
http://forums.corner-carvers.com/index.php
I have the Steeda steel u/l conrol arms. They`re more money, but they`re designed to work for DD, or racing. The bushings are designed to prevent binding or torque box damage. Good luck.
ORIGINAL: Chopper
Well I made some e-mails and--->
Stangmods.com recommends Steeda nonadjustable lowers ($200)
Stangsuspension.com recommends Max. Motorsports Non. Adj. lower ($250)
Or I can get the UPR Chrome Moly Uppers and Lowers for $200 shipped
Tough decision
Tough decision
