thinking of the New Trickflow intake
ok so my buddy has a 2001 mustang GT. He is thinking of getting the new Trickflow 2v intake this one http://store.summitracing.com/partde...p;autoview=sku
He is wandering which throttle body to get I suggested the Accufab 75mm to go with it http://www.americanmuscle.com/ac75pothbo9g.html.
Or maybe the BBK I don't think its gonna matter the Accufab jus looks nicer and for $10 or so more why not lol.
Which throttlebody would you get to compliment this Intake?
I know the intake jus hit the market and he has been waiting for the oppurtunity to get a new intake cause his plastic one cracked and weve been hearing a lot of hype and good things about this intake so he is gonna try it and if it turns out to be good I am gonna get one too. thoughts?
RE: thinking of the New Trickflow intake
ORIGINAL: sstang
Any 75mm will be fine really. What intake piping is he gonna go with?
I was under the impression the trickflow 2v intake is a bolt-on it should work with the stock setup well it says direct bolt on in its descriptions Ive read. And it has a 75mm bore so if anything you had to get it would be a 75mm throttle body that was my impression.
ORIGINAL: thornton02GT
isnt it like 800 for only like 30 HP(MAYBE?) : /
I don't see that intake bolting to the stock air pipe. I'm referring to the pipe that goes from the air filter to the throttle body.
He won't gain 30 hp. I wouldn't see any more than 15 rwhp at the most. The factory intake is not that bad at flowing, plastic is its only downfall. If he has the money though, it would be good for him though since he will be running nitrous. A nitrous backfire will fugg up the stock intake. I havnt seen any dyno results yet from this intake though, so Im not completely sure. All i know is most after market intake manifoldsdont do well on a stock N/A engine.
There was a post over at another site. Supposedly it was straight from trickflow that on a bone stock 02 GTit made 20rwhp at 6000 rpm.
Ive heard that its designed as a direct bolt in. Its supposed to be able to use the normal inake tube and it looks like it will.
ORIGINAL: sstang
If worse comes to worse I still have my stock piping and we can modify that to work with it. But according to the descriptions.
I am sure trickflow designed this intake to work with after market cai setups it would be retarded not too since 90% of people modding these cars thats the first thing they do is change the cai.
Qutoed from summit racings description for the intake.
Track Heat performance for 4.6L 2V Ford Mustangs.
Add some ponies to your Mustang with Trick Flow's Track Heat 4.6L 2V intake manifolds. Designed for hot street and track-ready 4.6L SOHC Mustangs, the Track Heat 4.6L 2V manifolds improve performance in the meat of the engine's powerband between 1,500 and 6,500 rpm with unported cylinder heads and 1,500 and 7,200 rpm with aftermarket or ported cylinder heads. The secret lies with the symmetrical high-velocity intake ports and 75mm throttle body inlet, which work together to substantially increase airflow and distribute it evenly to the cylinders. With these revolutionary intakes, you will be rewarded with big increases in performance over more expensive manifolds! Plus, the intakes' A319 aluminum construction is not affected by nitrous like weak, plastic factory manifolds. And don't worry about hood clearance--the Track Heat intakes are direct bolt-on replacements for stock and will fit under any stock-height hood. "
So I am assuming by the description it works with all the stock stuff since in the description it clearly states it but I guess I wont know till I go to do it lol.
