Little black wire
11-08-2004, 10:32 PM
I ♥ Acer
RE: Little black wire
Up load the picture. Or i could always just go outside and look at mine. lol. Its too cold out though. Maybe tmrw.
11-09-2004, 02:39 AM
you should fallow the harness or whatever its from and see where it leads. it just may leave a clue for you.
11-09-2004, 06:06 AM
i wasnt able to get a pic today, but i should have one uploaded for sure mid tomorrow, maybe it is a ground wire like 98brtatlanblugt says?
11-09-2004, 02:17 PM
ok if i can get this image insert to work, here it is
its kinda hard to see in the second pic, its more of a inside the boot shot
11-09-2004, 02:33 PM
that goes to your egr, there is a little thing sticking on the top of the egr valve, that is where the wire goes-it just plugs into it. look at your egr and tell me if that was the case
11-09-2004, 02:57 PM
nope, i already have that one on there
11-09-2004, 11:43 PM
I ♥ Acer
whats youre check engine light on for???? Im going down stairs to look at my 98, i'll post back.
11-09-2004, 11:57 PM
not too sure but you have the PI head swap it might be a difference in the coil on point ignition the the twin coil packs. other wise i think its a ground wire.
11-10-2004, 12:28 AM
o2 and 00125 which is somthn to do with coolant, na, cuz its comin out of the wiring harness that runs to the injectors which i never changed
11-10-2004, 12:35 AM
yeah could go to a temp sensor on the block souns right looks like one anyhow could be why check engine light is on too
