would these mods change my 1/4 time at all
ok so with these on my car and a good day good or ok driver what would i most like run and around how much hp to the motor would it be
o/r h mac
flowmaster mufflers
diablo tuner
c&l mass air meter with k&n air filter
steeda udp
bbk 70 mm tb
and 373 gears
and also im at the point of saving for cams how would stage 1 cams do along with those mods
o/r h mac
flowmaster mufflers
diablo tuner
steeda udp
bbk 70 mm tb
and 373 gears
RE: would these mods change my 1/4 time at all
The cams will make a difference but it won't be massive.
The biggest advantage a aftermarket cam has over the stockers is the powerband after about 5500 RPM. I didn't gain much (about 15 WHP) peak with the stage 2s, but I gained 30 WHP at redline (6000 RPM). N/A the car was falling off around 5500, with the stage 2s (before the blower) it was pulling all the way to redline.
want a good laugh about 1/4 racing??
ME bullitt with 4.10s, 275 nitto all around + a 200 pound friend
HIM 03 gt, aluminum drive shaft, eaton diff, same tires, 410s and LCA
1st run, i win by half a length
2nd run he misses 3rd but before that neck and neck
3rd run i give to much gas and im at his door
mods do not mean everything! [:@]
i would save your money on some of those and invest in suspension and some good tires. horsepower isn't everything if your spinning. who cares if you have say 350hp but your pulling 2.5 60ft times? the guy with less hp pulling say 1.8 60 ft times will beat you
