Mark VIII
Mark VIII
is there anything really good about this engine for my mustang, i know where i can get one really used so it would need to be rebuilt anyhow, but is it worth picking up to rebuild and put in my gt
RE: Mark VIII
ORIGINAL: Fuel
so it is the telskid block
RE: Mark VIII
so if i can pick up the whole car for a couple hundred $s then it is worth it to at least get the block soi can build a new motor without having my car down(since my curent engine has 198000miles on it)
anything else worth swapping over, how are the heads etc.
RE: Mark VIII
You can't put 2V heads on that block(well you can but it's a lot of work).
Seeing how your engine has old ***** I would deem it worthwhile to pull the whole 4V motor and throw it in your car.
RE: Mark VIII
these aren't the same 4v heads as the ones on the 99+ cobras though right, and i could put the intake from the 99+ cobras on it to have the correct mustang intake configuration, right
RE: Mark VIII
ORIGINAL: Fuel
Mark
cast crank 6 bolt
smaller cams
low rpm intake
low rpm valve springs...I think
Cobra
better cams
better intake
forged crank
RE: Mark VIII
well, cams aren't cheap for a 4v, aftermarket cams can cost about $1,200. the tranny should bolt up, if you have an auto the 6 bolt crank should fit up i'd imagine, if you have an manual which i think is 8 bolt, you'll just need to get a 8 bolt for the crank or however it works. rebuilding the engine might be more of a pain that just finding one with low miles to just drop in the car.
