Just hit 60k!!! What 60k service to do?
RE: Just hit 60k!!! What 60k service to do?
+1 on the belt
ORIGINAL: BADSEED
mines at 61K im gonna be changing Plugs, radiator flush, air filter, fuel filter, brakes are still from the factory, tires, belt and a couple of sensors
what sensors need to be changed do you think?
Also how much does a belt cost? easy to install?
and what brand plugs to get? (any minor power difference with better brands?)
Im on 60,000 on my GT. I just got done servicing my. Changed the plugs to autolite double platnium, changed fuel filter, belt, coolant(flushed), drained oil and put in Mobil 1 synthetic with mobil 1 filter, oil pressure sending unit, clutch and had the flywheel resurfaced. If yourgoing to change the fuel filter, get the hose tool! The car had a K&N Filter so i recharged that as well. Check your exhaust for leaks, check the breaks. Disconnect the battery on your car for about 10mins, then reattach it, get into the car, put the key into the "On" position and watch your gauges, they should do a full sweep, then start the car. Everything should check out for you.
