Tech question please!
can i take my thermostat out, hook hose back up to flush block? that way water continues to run through?
as long as i keep hose in resevoir and plug out will this work or mess things up?
i am trying to get all the antifreeze out without jacking up to get to the plugs on the bottom
RE: Tech question please!
Yes you can if you want. Be careful with the stat housing. They break easy. Also, never mess with the freeze plugs unless you really need to. Or,that could turn into a very expensive coolant change.
What kind of coolant are you going to use?
ORIGINAL: sprostang
when i just took out thermostat the rubber surround came off seperate wouldn't hurt to just by new thermostat huh>?
http://store.summitracing.com/partde...p;autoview=sku
180 degrees is that about right?
summit 10 min away
summit 10 min away
Yeah, I would replace the stat if your takin the old one out anyway. I dont know about the 99`s, but my 04 takes a special kind of coolant. If yours doesn`t require that, you should get the pre mixed coolant. Alot easier.
ORIGINAL: sprostang
i got green
peak for all makes and models
ORIGINAL: sprostang
ORIGINAL: dirtystang04
What kind did you use? I plan on changing mine soon. Did you get the pre mixed stuff?
ORIGINAL: sprostang
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
