I have an Accufab 75mm throttle body and an Accufab plenum. The mounting holes don't line up. Will these not work together, or is there some sort of adapter needed? Thank you!
Bump. Neither part is stamped with an Accufab part number but both are Accufab. The 75mm TB looks like it should flow smoothly into the Accufab plenum. I can't be the first Mustang owner to face this. C'mon, what's up? Why don't the TB and plenum bolt to each other? What do I need to make them work together? Thank you!
can you take pics of them? I've got both the tb and plenum from Accufab and they line up fine. I'd have to look at mine, I'm not sure if they have a part number stamped on them or not.
