Adding More Power to My Mustang (newbi)
RE: Adding More Power to My Mustang (newbi)
ok, you can start with an exhuast (headers, midpipe, and catback). intake, throttle body and plenum, gears (though they wont give you power, itll give you better acceleration). You can also get some giggle gas or some sort of forced induction.
depends how much power you want? want 400+rwhp? or you just want a little more then stock like 280ish?
400+ = supercharger or nitrous
280ish = Exhaust, Cams, Tb/Plenum should get you there..
ORIGINAL: rbstang
ORIGINAL: ZW99GT
Its gonna be tough to get a stockish GT from 230 to 400+rwhp on the spray. Thats a 175-200 shot depending on brand.
ORIGINAL: rbstang
Good starter bolt ons are:
*CAI (I like MAC personally)
*Gears (Pro 5.0 saves 3.5lbs over stock gears for quicker revs, I would suggest 3.73's for a manual, 4:11's for an auto)
*Exhaust w/ X-pipe (Your taste, a lot like flowmaster, Borla, Stainless works, Bassani)
That combination will make you very happy and it will cost you under $1000 bux.
After that you can get:
*Typhoon aluminum Intake and large TB (Combo good for around 30hp as tested by MM&FF.)
*Larger maf w/ larger fuel injectors
*UPD Pulleys
*Shorty Headers
*Lightweight flywheel or flexplate
*PST Carbon Fiber driveshaft
*Custome Dynotune
And then there is still a ton more that you can do, port and polish, cams, shortblock, more fuel and timing, Forced induction, nitrous the list goes on and on.
Do what you can at first and enjoy the car, welcome to a new lifestyle
-Eric-
*UPD Pulleys
*Shorty Headers
*Custome Dynotune
-Eric-
ORIGINAL: NeoTokyo
*UPD Pulleys
*Shorty Headers
*Custome Dynotune
-Eric-
*UPD Pulleys
*Shorty Headers
*Custome Dynotune
-Eric-
the tyhpoon adds nothing (even with a built motor its nearly worthless execpt that its not plastic so you can spray a larger shot and not worry about nitrous backfire), larger injectors/maf are going to do nothing at his power level, short tubes are good for 5~ WHP if your lucky, and the carbon fiber driveshafts are not that much lighter than an aluminum one and have a tendancy to explode when hit with road hazards like rocks.
So far as the lightweight flywheel... you can argue it either way but it doesn't make a large enough difference to justify pulling the tranny off the engine and the 300+ dollar cost.
I don't understand why people post tech info when they do not KNOW what they are talking about. Some people will acutally go out and spend the money on parts that are recommened here, so think about that before you post.
Exhaust (with longtubes, just stick with stock manifolds on a bolton only car if you cant do em) gears, and the intake boltons are all great mods if your just starting out. The skys the limit depending on your budget.
I started with a JLT RAI (afraid of rain) 70MM Accubfab TB/Plenum combo and a diablosport tuner. To tell you the truth, I did it beforeI started readin these forums and I didn't get much power return.
I put all of the parts in ymself and it was very fun and rewarding when I drove the car and it didn't break. A lot of the suggested things to do at the beginning are usually not feasible for the beginner to do, but I hope that you'll find something you can do yourself because it makes you feel like a part of your car (or vice-versa). At the very least, find a shop that will let you hang around and help out while they work on it. Good luck and have fun!!
