crower cams on patriot heads stage 2
Is this cam to much for my (auto) 2000 gt without installing a stall converter????
Stage 2
Hot street profile.
Emphasis on mid range.
Spring Recommended.
RPM range: 1250 to 6000+ on 4.6L, 5.4L will be lower.
254 Lobe 258
268 Valve 272
208 Lobe 212
224 Valve 228
.559 / .570
84701
Stage 2
Hot street profile.
Spring Recommended.
254 Lobe 258
268 Valve 272
208 Lobe 212
224 Valve 228
.559 / .570
84701
RE: crower cams on patriot heads stage 2
i put them on my 96 when i did the pi conversion and wow i love the mid range. slight lope at idle noticed with good exhaust.i think you will be fine. add some gears and you will love it..are you pulling the heads off? make sure you use the crower springs and retainers they are rated for more lift than the comp ones..
junior04
09-28-2015 10:53 AM
