non pi twin turbo project complete(remote)
First off I would just like to say that every bit of this was built by hand nothing came as a kit everything was fabed at home. I have about 2000.00 in this project not including the tune. This was also done in only 5 days this past week over spring break. I am super pleased with the turn out of this project and have clearly met a reasonable max for the stock internals on a mod motor non pi or other wise. The car made 403hp and 427ftlb @ 8psi. I am happy with the install and I hope that for all the non pi'er guys out there will finally see just what can be had with stock heads if the right mods are used.
RE: non pi twin turbo project complete(remote)
The turbos are close enough to the diff to clear bumbs but the front pipes and hangers have scraped here and there....not any worse than a lowered stang. Clearance isnt all that bad. They start really pooring in the coals around 28-3000rpm. They are T-3/T-4 57mm It makes launching easy I noticed way better weight transfer and more traction, plus the boost comes on easy at first then rips it a new one after you get rolling sort of.
Yeah that is not the best place for the filters but it doesnt rain to much and the next big break I have off I may move them in the trunk or make the side scopes function with a drip drain similar to a mach 1 hood shaker only with each of the little side scoops. I just flat ran out of time to get that perfected.
