What kind of RWHP would this Mach 1 produce?
RE: What kind of RWHP would this Mach 1 produce?
[8D]
Not even close.
It'll be at or above 300RWHP. It'll make more with a dyno tune...
It's capable of 12's no question, taking the driver out of the equation.
ORIGINAL: CobraSnake
Oh it will be in the 12's no problem. I would say around 350-360rwhp just a guess though.
that my friend is the truth.....id say this mach should make 310 or so. no problem. i bet it sounds good.
ORIGINAL: Miliock
I have to ask, cause it makes no sense to me....why go with a heads/cam setup on the 2V motor when you will get alot more power fora little more (maybe the same)$$ with a S/C kit from someone like vortech?
ORIGINAL: GT03 TJS
maybe i just didnt know as much about mach 1's as I thought I did, but all those mods and only 300ish to the wheels?
I cant say I'm too impressed....my friend has a mach 1 with a Mac Catback which is otherwise stock.....and sounds like after I do my heads/cams I could probably run with him. since the above mentioned mach would probably thrash his.....
ORIGINAL: Dan04COBRA
[8D]
Not even close.
[8D]
breaking
10-02-2015 01:27 PM
