Weird box hooked up to possibly o2 sensors?
Im installing my short shifter and noticed theres a black box, that has a power wire connected to the cig. lighter, the wires lead down to the trans. I cant really tell if it goes to the transmisson, or o2's but there is mil elimiators already ( Owner did this before)
any idea?
any idea?
RE: Weird box hooked up to possibly o2 sensors?
Most likely gears.. mine didnt have any codes to put in if I had different size tires/wheels... It only gave info on what code to put in if I had whatever gears.
It should say SpeedCal on it... does it not?
ORIGINAL: Greco400
It doesnt say no name on it, but my speedo does not work either, is there any way to check to see if there is gears the tires and rims are stock
Yes. Raise the back of car, make a mark on the driveshaft, spin tires 1 revolution, count how many times the driveshaft turns.For example, 3 1/4 turns = 3.27`s---3 1/2 turns = 3.55`s--- 3 3/4 turns = 3.73`s---4 turns = 4.10`s---- etc.
jwog666
12-27-2021 08:09 PM
trashxtrash
09-20-2015 10:49 PM
