BATTERY HELP!
BATTERY HELP!
Ok so while doing my LT istall i went to go take the negative batter terminal off and on th first try of a turn to get it off it snapped into several pieces. It was corroded but I did not think it was that bad. How do I got about fixing this? If you guys do not know what I mean or want to see how bad it is I can take pictures. Thanks in advance.
RE: BATTERY HELP!
if you go to autozone, they sell replacement terminals that you can install by cutting some of the wires, removing the rubber, and connecting it to the terminal via tightening a bolt or soldering. i did this on my ex g/f's mountaineer. its about a 20 minute fix. just make sure to disconnect the positive before doing any of this to be on the safe side.
logan409
09-26-2015 07:43 PM
