EMERGENCY!!!
EMERGENCY!!!
Ok so i just replaced my cracked intake manifold put everything back together, started the car and coolant starts to spill out under the car, it is also idleing really rough. the wierd thing is the coolant level is not dropping at all and the temp is fine too. please help. thanks
RE: EMERGENCY!!!
Well, you obviously have a leak. The rough idleing is from the leak... Find out where your leak is coming from, either you forgot to put a hose back on, have bad gaskets, didn't tighten some bolt(s) tight enough, etc.
KingRando
10-01-2015 11:16 AM
drob544
02-03-2006 09:55 PM
