Anyone else running flows on mac o/r h?
RE: Anyone else running flows on mac o/r h?
ive got the prochamber, pretty much the same thing, i just used an electric impact wrench, i went as tight as i could untill the flanges holding the bolts started bending and i was like wooooooh stop, i think i still have a leak at the headers though. thats more important than at the catback, bc whenever you turn on the heater when stopped thats what you smell, gasoline fumes... i like it, but everyone else that rides with me, not so much
ORIGINAL: krm486
Did u get the 3 pc o/r H? Mine sealed up good however my flows are welded in. U probably have done it a few times already but loosen and try again.
I'll probably tear it down and try again this weekend.
Put it alltogether butleave the bolts loose. Take ur time andmake sure everything is lined up. Gradually tighten each bolt as u would the lugs on your wheels.Then crank the hell out of um!
I got fed up with mine and had to have it realigned at a muffler shop..... Good Luck!!
Luke9222
10-22-2015 11:55 PM
09-10-2015 08:39 PM
