Wheel spacers.
RE: Wheel spacers.
ORIGINAL: Aixtreme89
How difficult is it to replace the studs in the axles? Just use a hydrualic press to press them out and in? Does the ABS sensor just slip off, so it doesnt get in the way?
RE: Wheel spacers.
It was a PAIN! I pounded the old studs out with the axles in the car, than I took the axles out and installed the new ones. I did not take the ABS sensor off, but the studs will just wedge in there with a little tap with a hammer. Then I got a punch and a hammer and drove them home. Oh, and on my studs I ground a tiny bit of the nurls down so they would pound in a little easier cause at first they would not go in at all....
RE: Wheel spacers.
ORIGINAL: 03greyGT
Question. What lug nuts do you use now? Are you using the caped ones or the through bolt ones? And if your using the through bolt ones how far is the stud sticking past?
RE: Wheel spacers.
Im not too worried about the bearings cause I have a whole rebuild kit for the rearend thats goin in it when I get my gears changed. As for the lugs, I bought the ones from american muscle that look like a big allen bolt. The pattern is on the inside of the lug. I currently had to take them off the back till i trim up the studs a little...
jwog666
12-27-2021 08:09 PM
mungodrums
09-28-2015 10:54 PM
