Brake Squeek. Need Help.
hey guys. when im crusing along, there is this constant and annoying squeeking coming from my rear drivers side wheel. i have no clue what it is. i sprayed the CA w/ wd40, and cleaned the **** out of the rotor got all the rust off and everything, even sprayed brake cleaner until it looked new, and it still squeeks.once i hit the brakes, it still squeeks, but its not as bad. i have no clue what it could be. any ideas??? thanks.
RE: Brake Squeek. Need Help.
Yes, the rotors could be warped if they werent machined the last time you did a brake job or if they were not machined properly and are starting to get warped. Could also be a wheel bearing.
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
