wheel scraping
Old 03-23-2007, 01:35 AM
oxfordgt
oxfordgt's Avatar
Default RE: wheel scraping
Measure from the corners of the bumper to the ground on both sides. Then have someone sit on the cornors (one at a time) and measure again. If it is lower on the side then it is blown.
oxfordgt is offline
Old 03-23-2007, 01:37 AM
LetThePoniesRunFree
LetThePoniesRunFree's Avatar
You're going to naturally torque to the passenger side on launch. Could be a spring going soft after to many launches? The shock isn't going to stop compression, just slow it down.
LetThePoniesRunFree is offline
Old 03-23-2007, 01:38 AM
jpmustanggt
jpmustanggt's Avatar
So its either a spring or a shock?
jpmustanggt is offline
Old 03-23-2007, 01:42 AM
oxfordgt
oxfordgt's Avatar
My buddy had the same kinda problem where he would rub when going over bumps and taking off from a stop. We changed out the shocks first because they were only $14 a piece and it solved his problem. This was on a 95 GT but it is still the same suspension.
oxfordgt is offline
Old 03-23-2007, 01:47 AM
tehzack
tehzack's Avatar
I was thinking sway bar too. Check your shocks while your at it.
tehzack is offline
Old 03-23-2007, 01:49 AM
LetThePoniesRunFree
ORIGINAL: jpmustanggt
No, it could also be a sway bar bushing/link, upper/lower control arm link/bushing.
jwog666
12-27-2021 08:09 PM
UrS4
10-03-2015 06:23 AM
mungodrums
09-28-2015 10:54 PM
folivier
09-26-2015 02:28 PM
lincolnshibuya
09-24-2015 10:46 PM
Quick Reply: wheel scraping
