With the P.I swap...should I worry about injectors?
Old 03-24-2007, 03:21 AM
way2slo46gt
way2slo46gt's Avatar
Default With the P.I swap...should I worry about injectors?
When I do the P.I. Swap....should I swap out injectors? Or just leave it alone til SC'ed times comes??
way2slo46gt is offline
Old 03-24-2007, 04:27 AM
lizzyfan
Underboss
lizzyfan's Avatar
Default RE: With the P.I swap...should I worry about injectors?
Leave it be..stockers will be fine
lizzyfan is offline
Old 03-24-2007, 04:48 AM
AJ06GT
AJ06GT's Avatar
Yeah, you're not changing anything that will need the fuel system upgraded, you're just letting it breathe better. The engine is getting plenty of gas, it's just not being able to flow everything like it should.
AJ06GT is offline
Old 03-24-2007, 04:51 AM
98MustangSTL
98MustangSTL's Avatar
My only question is how much horsepower will you be putting out? Are the heads going to be ported? Cams? Bolt-ons? You may have to upgrade.
98MustangSTL is offline
Old 03-24-2007, 04:53 AM
AJ06GT
AJ06GT's Avatar
ORIGINAL: 98MustangSTL
I really don't even know that you'd need anything no matter what porting you do. You're not increasing capacity or adding FI or anything, you're just making it all flow better. Maybe if you have some other things done it might be time for an upgrade anyway, but not just from a H/C/I swap.
AJ06GT is offline
Old 03-24-2007, 06:59 AM
97targa
97targa's Avatar
ORIGINAL: AJ97GT
Think about it??? The 99-02 GT's had 19lb'ers! They upgrade to 22lb in 03 I bvelieve, but not 100% sure. I do know the came with pink toppers which is 22lbers! I would keep the 19's unless you were going cams and headers, then get 22lb'ers 24's may be a little much for those minor mods! 1psi per injector supports 16hp! 19psi=304hp You'll only be at 275 topps at flywheel with pi swap on non-pi
97targa is offline
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
Thunderball
15
11-22-2015 11:49 PM
Dathan
10-05-2015 05:52 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: With the P.I swap...should I worry about injectors?
