TB install and aftermath
Ok. I threw on a 75mm PP TB and a PP plenum back in DEC.
I noticed the neutral idle drop about 100 rpm after that and upon heavy excelleration i would get a whistle sound but only while in gear. So I got some new gaskets, plenum,tb,iac,egr. Checked all the hoses and stuff all the gaskets are new and on ,all bolts are snug, all wires connected.
Now no more whistle..
But now when comming to a stop I notice the rpm drops on occasion to 500 rpm.And the idle is still roughly 100 rpm lower than stock.
So before I go messing around with idle adjustments and crap ...I'd like you smart ones to give me some feedback.
Other than adjusting the Screw on the TB is there any other way to adjust the idle ?
I also have a tuner thats just waiting to run a tune ( Waiting to do gears before the tune)
Can the tuner assist this in any form ?
TY for the feedback
TY for the feedback
RE: TB install and aftermath
You do know that whistle doesn't mean something is wrong right? It happens to a lot of people with a TB and CAI. I doubt that it is gone. When I took mine apart cause I thought something was wrong, I put it all back and I was like yessss it's gone. A couple days later it will come back, maybe. don't know what I can tell you about the idle, all i knew what the screw and most companies tell you not to mess with it because it is preset at the factory
Hmm that could very well be true. That's probably why they say to disconnet the battery.I always thought it had to do with the "Shock" Factor lol
Im going to try that tomorrow.
ORIGINAL: 97modifiedmustangGT
Most times when there are idle issues it has to do with the throttle position sensor being installed slightly off. Generally the complaints are of a high or hanging idle but the computer compensates for it after it learns it after 15 minutes or soof driving after the TB install.
Notall cars will idle at the exact same rpm after the install. 100 rpm lower in your case isn't much to worry about in my opinion.
My car is auto, I have a CAI but stock tb/plenum. When in gear, I idle at probably 550 rpms, and occassionally when coming to a stop it drops to 400-450 and then pops back up to 550. I have always thought it to be slightly lower than it should be, but to the best of my knowledge it is no problem.
I don't think you have anything to worry about.
ORIGINAL: DTK
ORIGINAL: BleedinBlue
The whistle is normal, I personally love it . The idle with the car in park/neautral should be 800 rpms, while in gear it should be 600 rpms (as it comes stock). I dont know about other tuners but with my SCT tuner I can adjust RPM settings for when inneautral and while in gear.
