is there a way to LUBE THE TOB
RE: is there a way to LUBE THE TOB
ORIGINAL: IWinULose
More then likely it needs replaced if its making noise. Mine was replaced at 16k.
if do that why not pay 200 and just put another clutch in
You can remove the inspection cover and spray white lithium grease on the TOB. This sometimes quiets them down if they're not too far gone. I've not had a problem with mine since getting a firewall adjuster/quadrant and learning the proper way to adjust the clutch.
ORIGINAL: JayC
that was my next Q i need to properly adjust becuase last time it started i adjusted my clutch but messing around under tranny sucks............
i might go to summit today and buy one.............and get some white lithium grease
thanks
ORIGINAL: 99gtstang
thanks
ORIGINAL: JayC
thanks
ORIGINAL: JayC
Using a firewall adjuster there should be "zero" slack in the cable when pulled away (out from where it enters the firewall) from the adjuster. Just slowly screw the adjuster out until you feel all the slack being taken up then stop!
ORIGINAL: 99gtstang
thanks
ORIGINAL: JayC
thanks
ORIGINAL: 99gtstang
right now i have alot of slack it engages about 1inch from the floor. the guy who installed it said since everything was new from cable to clutch leave slack for when the pressure plate weakens and that way the clutch fork was not keeping pressure on the TOB. well it the pedal came up about 2 inches in a 1k miles so i loosened it some more..............and i started getting whinig about 5 k miles ago so i adjusted.... it quit then my pedal came up more so i loosened again now the whine is back.,
ORIGINAL: JayC
ORIGINAL: 99gtstang
thanks
ORIGINAL: JayC
thanks
ORIGINAL: JayC
Totally opposite of what you need. You want no slack in the cable and the engagement should be close to the top. This allows for the best clutch dis-engagement for fast and quiet shifting[8D]
ORIGINAL: 99gtstang
ORIGINAL: JayC
ORIGINAL: 99gtstang
thanks
ORIGINAL: JayC
thanks
see i was told different by tranny shop which is what my company has been using for about 10 yrs................ he's old school but i will try that
