11's here i come
well the stall converter, shift kit, valve body kit, trans cooler and deep pan are going in wednesday and in a few weeks im thinking of getting the VT stage 2 cams with comp valve springs installed as well as all this stuff has been sitting in my room for way too long. with just the stall converter though im expecting 11's so it will be a nice goal to see how deepI can get into the 11's this year
RE: 11's here i come
Cams are a big expense for a nitrous car. I got the same gains with 150hp jets. [8D]
Can't wait to hear what kind of times you put down. Good luck.
ORIGINAL: JayC Cams are a big expense for a nitrous car. I got the same gains with 150hp jets. [8D] |
ORIGINAL: DILO2001GT ORIGINAL: JayC Cams are a big expense for a nitrous car. I got the same gains with 150hp jets. [8D] Motor TrickFlow ported upper plenum BBK 75mm TB NX EFI Kit NX/MSD window switch SVT Focus fuel pump Speedy Dyno Tune (SCT Flasher) N/A & N2O tunes 180* T-stat Steeda Pullies 9"K&N w/ no airbox Denscharger MAF to TB only Flowtech Longtubes MAC o/r x-pipe Spintech ProStreets Dumped Hawker Battery Energy Poly Motor Mounts Drivetrain: FRPP 4.10's UPR shifter Energy Poly Trans Mount King Cobra clutch w kevlar disc Fidanza Al. flywheel Axle tubes welded Detriot True Trac UPR Girdle Moser Axles FRPP Alum. Driveshaft Suspension: Fox-body 4cyl springs(NAPA #270-3060) up front w/ Lakewood 90/10 struts Fox-body V8 rear springs (cut) w/ Monroe Sensi-trac shocks Airbag in RR spring No front swaybar UPR sub-frame connectors Steeda 4600 Lower Control Arms D&D adjustable uppers Torque boxes welded No quad shocks Wheels/tires Front - 165x15 on 15x4 Telstars Rear - 26x11.5x15 Hoosier QTP's on 15x8 TelStars Body/ misc Grill delete Mach 1 chin spoiler Steeda 3" Cobra R hood |
I don't know your mods... but i just hope you have a nice bullet proof axle, lol - or that things goin to snap like a toothpick.
I thought you already had some stage 1 cams... I guess not? or the stage 1's not good enough?
nah i ordered the stage 2's awhile ago and they have been sitting in my room for a long time.
ORIGINAL: JayC ORIGINAL: DILO2001GT ORIGINAL: JayC Cams are a big expense for a nitrous car. I got the same gains with 150hp jets. [8D] Motor TrickFlow ported upper plenum BBK 75mm TB NX EFI Kit NX/MSD window switch SVT Focus fuel pump Speedy Dyno Tune (SCT Flasher) N/A & N2O tunes 180* T-stat Steeda Pullies 9"K&N w/ no airbox Denscharger MAF to TB only Flowtech Longtubes MAC o/r x-pipe Spintech ProStreets Dumped Hawker Battery Energy Poly Motor Mounts Drivetrain: FRPP 4.10's UPR shifter Energy Poly Trans Mount King Cobra clutch w kevlar disc Fidanza Al. flywheel Axle tubes welded Detriot True Trac UPR Girdle Moser Axles FRPP Alum. Driveshaft Suspension: Fox-body 4cyl springs(NAPA #270-3060) up front w/ Lakewood 90/10 struts Fox-body V8 rear springs (cut) w/ Monroe Sensi-trac shocks Airbag in RR spring No front swaybar UPR sub-frame connectors Steeda 4600 Lower Control Arms D&D adjustable uppers Torque boxes welded No quad shocks Wheels/tires Front - 165x15 on 15x4 Telstars Rear - 26x11.5x15 Hoosier QTP's on 15x8 TelStars Body/ misc Grill delete Mach 1 chin spoiler Steeda 3" Cobra R hood |
ORIGINAL: Mark99GT ORIGINAL: JayC ORIGINAL: DILO2001GT ORIGINAL: JayC Cams are a big expense for a nitrous car. I got the same gains with 150hp jets. [8D] Motor TrickFlow ported upper plenum BBK 75mm TB NX EFI Kit NX/MSD window switch SVT Focus fuel pump Speedy Dyno Tune (SCT Flasher) N/A & N2O tunes 180* T-stat Steeda Pullies 9"K&N w/ no airbox Denscharger MAF to TB only Flowtech Longtubes MAC o/r x-pipe Spintech ProStreets Dumped Hawker Battery Energy Poly Motor Mounts Drivetrain: FRPP 4.10's UPR shifter Energy Poly Trans Mount King Cobra clutch w kevlar disc Fidanza Al. flywheel Axle tubes welded Detriot True Trac UPR Girdle Moser Axles FRPP Alum. Driveshaft Suspension: Fox-body 4cyl springs(NAPA #270-3060) up front w/ Lakewood 90/10 struts Fox-body V8 rear springs (cut) w/ Monroe Sensi-trac shocks Airbag in RR spring No front swaybar UPR sub-frame connectors Steeda 4600 Lower Control Arms D&D adjustable uppers Torque boxes welded No quad shocks Wheels/tires Front - 165x15 on 15x4 Telstars Rear - 26x11.5x15 Hoosier QTP's on 15x8 TelStars Body/ misc Grill delete Mach 1 chin spoiler Steeda 3" Cobra R hood |
