OD button and Fog Light Switch
Ok so we were on a roll yesterday as far as tearing stuff up. WE were doing a bung of minor repairs on my car and ran into a coupld of problems. First off we were changing the shirter plate, and had to take the **** off. My B/F accidentally broke the two OD wires off in the handle, so for now i can't use my OD. Is there a way to open the handle up to re-wire it. Or if i buy a new handle with the OD button from UPR will it have a new set of OD wires with it.
Ok and second we pulled out the Foglight switch to re wire it to work independently. Well the two pieces came apart and i can't get it back together. Has anyone taken the switch apart and remember how to get it together?
RE: OD button and Fog Light Switch
ORIGINAL: StangChik
I don't know about your year of car, but for my '02 I just popped out the foglightoverriderelay from the underhood panel & busted off one of tabs & stuck the relay back in. Took about 30 seconds to do lol
well this was supposed to be pretty easy too, but when i pulled the switch out the bottom square piece (the part with the harness in it), came apart from the top square piece(with the button in it) And now i canfigure out how to get it all back together and make it work, there's little pieces in the inside that i can't get right.
its crazy. I'm pretty good with this stuff, and i figured out how it works as far as connection go, but i can't get everything to stay together.
ANy idea on the OD button?
Im not sure about the way its all wired together , but if you do need to buy new parts like that this is the place to go http://www.latemodelrestoration.com/
They'll have your OD button and anything else you can think of.
I know this isnt the place to ask this, but I shall anyway---
I am trying to rewire my 05 gt to have the fog lights run independently---any idea where to find out how to do that, ive been searching everywhere~~~
Thanks!!
Thanks!!
yea on my old auto stang my wires got ripped too. I just popped the button out and bought some wire from murrays and soldered it back together and it worked fine. as far as the fog lights i just did the convertible top method, i dunno if you can do it or not since u have an actual convertible, but i imagine you may be able to tap into it.
TfcCDR
09-14-2015 12:08 PM
