pi heads
RE: pi heads
no i know a guy that has the heads complete with valves springs and retainers just no cams and was going to put the cams in them, just wanted to know if there was anything else other than windsor valve covers to make the heads fit on my romeo motor
also what do u hvae to do to the water pump or what not to make the pi swap fit
RE: pi heads
I dont think so you should be good to go. Make sure you understand how to time the car before you do it. Like read it over and over on how to do it. Also you have to get the newer water pump thing. I cant remember what its called but it has to run on the drivers side of the valley of the engine, right now its in the middle.
